disable iparp refresh
disable iparp {vr vr_name} refresh
Description
Disables IP ARP to refresh its IP ARP entries before timing out.
Syntax Description
vr_name Specifies a VR or VRF.
Default
Enabled.
Usage Guidelines
The purpose of disabling ARP refresh is to reduce ARP traffic in a high node count Layer 2 switching only environment.
If you do not specify a VR or VRF, the command applies to the current VR context.
The following example disables IP ARP refresh:
The vr option was added in ExtremeXOS 11.0.
Platform Availability
